Hi There ,
I'm engaged in the project of chassis design for a vehicle for the FSAE competition and i have to make the chassis with a sandwich (CFRP - Foam) material , since hyperworks (OPTISTRUCT) will  help doing the analysis , i started making a plate and making plies with CFRP (MAT8) and PCOMPP card image then a Core(MAT1)  with PSOLID property , also i make laminate with the plies . i applied the load with constrains then loadstep with both and i check CSTRAIN and CSTRESS Properties for the analysis but since i start the analysis there is no iterations made and only the one displacement result appear , i tried alot to change in the structure but still no iterations ,
Here is what i have and there is a copy of the hm file attached
The Results
Iteration Subcase     Variable  Grid/Elem ID   Value
   0    1 MaxDisp                    12205  -0.285887E-02
   0    1 MaxStress                   5725   -15.0120
The amount of memory allocated for the run is 331 MB.
 This run will use in-core processing in the solver.
 ANALYSIS COMPLETED.
 ==== End of solver screen output ====
 ==== Job completed ====
Sandwich Foam.hm
Hi mmramadan,
The analysis is completed and you can view the results.
I don't see any errors
I've changed only the magnitudes of the loads and then when i run the optimization analysis i got the same thing again , i attached an image of the results also
   0    1 MaxDisp                    10854   0.185177
   0    1 MaxStress                  13171  -0.115659E+07
Can you share the model files please?
Use the dropbox link in my signature below to share the files.
I have your model with me but I dont see any optimization parameters in your model. So that is why only analysis is done instead of Optimization.
Did you define any Design variable , design Response , design constraint or Design Objective?
If not please refer Optistruct optimization tutorials.
Regards
Rahul R
Hi mmramadan
i am designing a chassis for FSAE competition in China.
i think i am facing the same problem with yours and i do not know how to solve this.
could you please tell me how did you solve your problems
thanks for the help:)
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
