Sign in to follow this
VisSim Forum Archives
sampling for Ramp32
Submitted by Sreeram_Mohan_Altair on Mon, 05/16/2016 - 16:26.
Hi Andrew,
You should be able to set the frequency in the compound block within Ramp32 as in the image attached.
In this case the $timestep is the simulation step time accessible in the System-> System Properties Menu and the frequency as you read in this case is 60 Hz.
Hope this helps
--sreeram
