Sign in to follow this
VisSim Forum Archives
how to repeat ramp function in vissim embedded
Submitted by pete on Wed, 03/09/2016 - 20:36.
Hi Yogesh, There are a couple ways to do this depending on what you're looking for.
  • For a floating point fixed frequency repeating ramp, use
    Blocks > Signal Producer > sawtooth
  • For a fixed-point fixed frequency repeating ramp, use
    Diagrams > Toolbox > Fixed-point > Ramp16
    Diagrams > Toolbox > Fixed-point > Ramp32
  • For a fixed-point variable frequency repeating ramp, use
    Diagrams > Toolbox > Fixed-point > VariableFrequencyRamp32
Submitted by pete on Fri, 03/11/2016 - 11:50.
The msp430G2553 is a 16MHz device so each instruction takes .0625 usec. If we make a simple for loop that takes 3 ticks per iteration, we'll need 53 iterations. See how to do it in the attached diagram. (You must be signed in to download)
10-usec-pulse.vsm
Submitted by Yogesh K on Wed, 04/06/2016 - 16:26.
hii sir . its working but the result is not so proper.sometime it is not showing, may be this is because of off time . for proper working off time for this sensor should be 60 msec.so i calculate the for 60 msec 0.0625Usec * X = 60000 usec X= 960000 iteration i am right if yes how it implement in vissim emebdded. thanking you....
VNIT
Submitted by pete on Wed, 04/06/2016 - 19:56.
Yogesh, You don't want to do a "spin" loop for 60 millisecs, that's way too long. Instead use a hardware timer, or counter based off the control timer interrupt that runs the diagram. Post the diagram you are currently using and I'll modify it for you. It will be a bit tricky since you only have one timer on the part you are using.
Hi Yogesh, As sound travels .344 meters /millisec, we can just count the millisecs until we get the return pulse, and distance is millisec count * .344/2.
See attached file below. Note that I don't know which GPIO you are listening on, nor do I know what you want to do with the distance, so you'll have to handle that yourself. I am sending it to an external variable right now.
You may have to add some blanking logic to ignore a sensor pulse that you get when you initially send the pulse out.
Here is an image of the diagram:
distance sensor diagram Pete
ultra2.vsm
Submitted by Yogesh K on Tue, 04/26/2016 - 16:04.
hii sir i want to compare " distanceMeasure" with my reference value. and output gives to the motor,but when i connected to my launchpad , it is not showing any high value , may be this is because of variable i used wrong syntax. if any changes tell me . thanking you
ultra3.vsm
