Sign in to follow this
VisSim Forum Archives
how to use PWM in msp430G2553??
Submitted by yogeshnand on Wed, 03/16/2016 - 15:56
VisSim 9.0
i am learner of VisSim embedded. trying to use PWM , but when i connect square wave block to PWM , it shows error " type mismatch on input 0" how this error would be solved.i am using MSP430G2553 As a target. thanking you..
Submitted by pete on Wed, 03/30/2016 - 07:28.
Since TA0 is the only timer on this chip, you need to share it with the PWM and control interrupt generation. To do that the periods must agree. The easiest way is to choose a control rate, generate code, and look at the value VisSim assigns to TA0CCR like so:
  TA0CCR0 = 0x3e80; // Timer Period
Then convert 0x3e80 to decimal (16000), and use that as the PWM period. See attached.
pwm2.vsm
Submitted by yogeshnand on Wed, 03/30/2016 - 14:55.
thanks for your reply. but sorry to say it showing the same error. same way first i generate code , took values of TA0CCR , convert ed into decimal and used this value for PWM period. but it showing the same error. ""Warning!PWM causes timer TA0 period conflict".
