Sign in to follow this
Is it possible to hide the X-Y-Z triad of a tracking system?
I would like to be able to hide the X-Y-Z axes of a tracking system.  I can turn off the Global axes in the Preferences>Options>Appearance panel, but I can't find a similar option for shutting off the tracking system axes.
Hi!
is there a tcl/tk command in order to hide the  Global axes in Hyperview? I need for a scrip ;-)
In other words I want to do is to turn off the Global axes like with  the Preferences>Options>Appearance Panel, but with a tcl script
Thanks
Hi!
Thanks
Sure, there is
below is relevant commands:
catch {
     set ::post::optionsdialog::axes false
     ::post::optionsdialog::OnButtonPressed 1
B)
asalinasl likes this
I'm just placing the two lines
                    set ::post::optionsdialog::axes false;
                   ::post::optionsdialog::OnButtonPressed 1;
in a bigger script and I'm getting following error:
1 Error:   Tcl script error (Capture HI Res Image) : can't read "fgc": no
              such variable
              while executing
              "# Compiled -- no source code available
              error "called a copy of a compiled script""
              (procedure "ApplyAppearence" line 1)
              invoked from within
              (procedure "ApplyChanges" line 1)
              invoked from within
              (procedure "OnCloseDialog" line 1)
              invoked from within
              (procedure "::post::optionsdialog::OnButtonPressed" line 1)
              invoked from within
              "::post::optionsdialog::OnButtonPressed 1"
Thanks for the help!
That's why i put it in "catch" command
perhaps you need to open appearance panel once before run your scrip
or add below code once when start hyperview:
after 50 destroy .postOptionsDialog;::hw::ExecuteMenuItem 263;
Tinh,
you are right!! ;)  If I firstly open the appearance pannel, then my script including the two added lines works quite well by turning the axes off and afterward again on.
The question is how can I automatically open that Panel before I run my script. You wrote  about doing that when hyperview was started. Could you give me more Details about that?
The best solution would be to add some code in my script to open the apperance Panel automatically in order to get the two lines:
working. :wacko:
Thanks for your advice!
ah, you need not to open it once when starting hv.
try add below code into your script
if {[catch {
        after 50 { destroy .postOptionsDialog;update
                       ::post::optionsdialog::OnButtonPressed 1}
Hi Tinh!
I copied the code that you posted but the problem persists. i.e. I always Need first to open the appearance panel in order to get  the axes to disapper.
The script works but at the end I always got the following error:
can't read "fgc": no such variable
    while executing
    invoked from within
    invoked from within
    invoked from within
    invoked from within
    ("after" script)
Regards
Alfredo
