Sign in to follow this
VisSim Forum Archives
Importing non time based data
Submitted by Anders89 on Wed, 12/05/2012 - 13:21.
Yes, use the "dialogTable" block. It works with a parametric data in .csv form organized by row. Each row consists of a new set of parameters. The first column of the data set is a name used to identify the row. It will appear in a drop down list in the dialog box. The first row consists of header names for each column. The header names will be placed on the output pins of the dialogTable block. You can try an example of a dialogTable block under Diagrams > Examples > Blocks > Signal Producer > dialogTable
