Aurea
Gravity in forming simulation
Hi!
I am using the RadiossBlock (Block140) in Hypermesh for a forming simulation and I want it to consider the force gavitational, can you please help me?
I already read the tutorials in the page, but I think they are not based in the same Block that I am using, but in he Abaqus (Standad3D) block.
Thank you very much in avance.
Thanks. I am going to try this.
In the Curve ID, what do I have to put if I want the gravity to be during all the simulation? in the values of X the time peiod and in the values of Y, 1 or 9810 ? I mean, I don't know if the function already takes ino account the gravity value or I have to re-write it.
in the screenshot below, I wrote in the curve in the values of Y -9810, and int he X and Y scale factors also, but I get the rows in the positive direcion of Z and I want then in he negative direction. What am I doing bad?
Hi Aurea,
Create a curve in XY Plots>>Curve Editor for gravity load and recall that curve in Curve ID for creating a gravity load. Maintain Scale X and Scale Y values as 1 itself.
For creating the gravity in negative Z direction (as in your model) , either you can provide -9810 value in the function you are defining or you can input Scale Y value as -1.
I have a curve like that already defined.
but my gavity is in axe Z. do i have to still put -1 in the Y scale? and in the x scale I leave the value of 1, isn't it?
Thank you very much for the help
Aurea,
If the values in the curve are -9810 then let the Scale X and Y values be 1 itself. Then the load will act in negative Z direction.
i am trying as you told me but now the plis move in the Y direction.
it is not a problem that when I define the courbe I give values to X and Y and then I say the gravity mouvement is in Z?
Direction of translation will be the direction you specify.  X and Y are meant for scaling only.
If problem still persist, please share your model
