Sign in to follow this
Felix Baumgärtner
Start consecutive independant optimizations
I have prepared several independant Optimization studies based on the same model, each of them takes 2 to 3 hours to complete the maximum of 400 iteration cycles.
Is there a possibility to evaluate each task consecutively by using one command?
I would like to avoid to start the evaluation of each task seperately, in order to run all tasks overnight.
The Optimizations are fully prepared and only require to be started by hitting the "Evaluate Task" button. See the attached screenshot for further Info.
Thanks for your suggestions in advance!
Cheers,
Felix
Quote
Unfortunately, you cannot evaluate multiple approaches at once. However you can run the study in batch which will eliminate the need for you to click on evaluate for each approach. Hope this helps.
Rahul R likes this
In online help, under "Invoking HyperStudy" section batch commands are listed for different OS. As for picking what to run in batch; in the UI; if you click on the study name; you will see that one of the tabs is called "Batch Tasks". In this tab; you can pick which approaches you'd like to run batch. Hope this helps.
