Sign in to follow this
Sagar Desai
retrieve surfaces
Hello
so I am creating a program in which I trim a surface with lines
and in later part I retrieve the trimed surfaces automatically (using *createmark surfaces 1 -1 -2)
Quote
*createmarkpanel surfaces 1 "select surfaces"
*createmarkpanel lines 1 "select lines"
*createvector 1 0 0 1
if { [ catch {*surfacemarksplitwithlines 1 1 1 9 0 } ] } {
# Handle error
*interactiveremeshsurf 1 4 1 1 2 1 1
*set_meshfaceparams 0 5 1 0 0 1 0.5 1 1
*automesh 0 5 1
*set_meshedgeparams 1 19 1 0 0 0 4 0 0
*automesh 0 5 1
*storemeshtodatabase 1
*ameshclearsurface
have alook at image attached
so i want meshing inside the inner circle and in between the two circles
and I also would like to know  how  *createmark surfaces 1 -1 -2 works??
I am able to wish only part in between two circles with above program
so how can I assign the inner most surface directly I tried all -1,-2,-3 its not working
and I also want that newly created inner most mesh should be organized in a new component "TAP WELD"
Hello
so I have made some changes and now I am able to mesh both the parts properly
Quote
# Handle error
*createmark surfaces 1 4
*interactiveremeshsurf 1 5 2 2 2 1 1
*set_meshfaceparams 0 6 2 0 0 1 0.5 1 1
*automesh 0 6 2
*ameshclearsurface
*createmark surfaces 1 -2
*automesh 0 5 1
*automesh 0 5 1
*ameshclearsurface
still working on organizing the element to a perticular component
let me know if anything is wrong in above programs
Thank you
so I am able to organize the elements into components name which is given in the script
Quote
# Handle error
*automesh 0 6 2
*storemeshtodatabase component1
*ameshclearsurface
*automesh 0 5 1
*automesh 0 5 1
*ameshclearsurface
now I want to create those lines created around the hole (washer automatically) probably twice the radious of the hole
hello
there is a problem in my file I am not able to understand please see if you can help
I have a surface having hole and washer (grey) and another overlapping surface on it (L section blue) no hole and all
so I have written program which will trim the l section blue surface with the hole and washer line on the gray surface
and then mesh the inner most and in between part with given parameter
but its not meshing how I want (or by defined parameter)
and also its meshing all the outer part which I dont want
""3.png"" is how I want but I am gettinh as shown in ""dont want like this""
