nextdc
IsoSurface.Value error
Hi AltairHW
I'm using FEKO 14.410 EDU edition and experimenting with the script example https://www.feko.info/support/lua-scripts/radiation-hazard-iso-surfaces/radiation-hazard-iso-surfaces-wizard
When running this code I receive an error when setting p1.IsoSurface.Value = 41
"POSTFEKO 14.0.410-277905 (x64)
c:\Development\Workspace\win64_Maintenance\utilities\geometry\include\common_RangeOf.hxx (41): Assertion failed: !isEmpty() "
If I comment out this line the script completes without error.
I can't determine why p1 is failing to set the value.
What is strange is p2 is a duplicate of p1 and it will set p2 value without error.
p1 = app.Views:Item(views+1).Plots:Add(scaledNearField)
p1.Visible = false
p1.PlotType = "Iso-surface"
p1.Legend.Position = "None"
p1.Label = ("RMS_Public" .. append_to_label)
p1.Visualisation.Opacity = 40
p2 = p1:Duplicate()
p2.Label = ("RMS_Occupational" .. append_to_label)
p2.Visualisation.Opacity = 40
-- ERROR OCCURS HERE WHEN SETTING p1's isosurface value
-- If I comment out this line the script completes without error
-- note that p2 successfully sets the value without error!?
p1.Visible = true
-- p2 is a duplicate of p1
-- can set p2 value without error
p2.IsoSurface.Value = 92
p2.Visible = true
regards
David
Hi David
I see that you are able to set the iso-surface value for p2 to 92, but that the error is given when setting the value for p1 to 41. Is this correct?
If so, it is possible that a value of 41 is outside your data range. Iso-surfaces can only be defined for data within the available range.
Johan
Rahul R likes this
