Sign in to follow this
Mike_Wu
Ask: How to set the shortcuts by command
I'd like to customize a shortcuts to let me get the function quickly to pick up the nodes attached with line.
I just know set the hm_pushpanel {rigids} to the subpanel (1D--> rigids), but what is the related command to let me also include below action?
1) select "multiple nodes"
2) select "calculate node"
3) select "by geoms"
4) select "lines"
I try to key hm_pushpanel {rigid} {multiple nodes} {calculate node} {by geoms} {lines}, but it is not workable.
Could anyone teach me how to set it??
BTW, does anyone know where I can find the command list in the help document??
Thank you in advance.
customizing panels are not usual documented fully. you can learn via sample script
example:
set ItemNumber [hm_getitemnumber rigids "calculate node"]
set ItemOwner [hm_getitemowner rigids $ItemNumber]
hm_setpopup rigids $ItemOwner $ItemNumber
with select nodes "by line". I didn't find direct command yet (using mouse hooking by twapi can do it, but it's a bit complicated).
if you want, try invoking sub proc like this
proc appendnodesbyline {{nodemark 1}} {
     *createmarkpanel lines 1 "Select lines:"
     if {[hm_marklength lines 1]} {
           eval *appendmark nodes $nodemark {"by lines"} [hm_getmark lines 1]
           hm_highlightmark nodes 1 h
           *clearmark lines 1
Mike_Wu likes this
I appreciate your reply. I think it's hypermesh's limitation and can't support to write the code into the shortcuts setting directly.
Anyway, I'll try your suggestion.
Thanks again!
