Sign in to follow this
Santhosh Rasamalla
Hyperworks Licensing
Maybe try this in file "altair-serv.cfg" of your license server:
# Set the minimum elapsed time for user removal.
# This will set a minimum time that must elapse from the connection
# before a user can be removed using lmxendutil.
# This time is entered in seconds, and must be equal to or greater than
# the number of seconds specified by your application vendor.
# Default minimum time is 120 seconds.
# If the time is set to -1, user removals will not be allowed.
# Example:
# MIN_USER_REMOVE_TIME = 120
