Nithish B S
what is the dof of CBUSH elements?
what is the dof for CBUSH elements? If i want to create a pin joint ain which i want to constraint  all dof except one rotation..what dof i must select while creating zero length CBUSH element among 1-6 dof??
CBUSH is a generalized spring-damper structural element with can take up to 6 stiffness values.If there are more than one stiffness we need to assign a local coordinate system id.
What exactly you want to capture with zero length Bush element?I have attached some documents from user guide for your reference.
CBUSH.pdf
PBUSH.pdf
