TUTULIKA
heat transfer within an enclosure using fan
hello all,
Warm greetings.
I am stuck up with the problem combining both the  use of a blower and radiation enclosure together.
I have studied fan component tutorial and radiation enclosure tutorial separately . But when I tried to use both within a analysis it is giving "Run time error" message.
Please suggest the possible solution.
Tutulika
If you are trying to use mesh motion (transient) with thermal, then it would not work. The enclosure based radiation model, works with stationary mesh.
In this case, moving reference frame might be helpful with transient thermal.
Rahul R likes this
