rimeca
"force controlled" and "displacement controlled" loadcases
Hello all,
I have a question about the equations behind the difference between loadcases that use forces vs loadcases that use prescribed displacements.
I am aware that these two loadcases lead to different results on Optistruct, but have found very few info in the help about it.
I did a simple test watching the behaviour of a part under torsion and bending when I try to optimize it on Optistruct (minimize mass, Von Mises static constraints, gauge optimization).
-When "enforced displacements" are used, we obtain a lighter part ( decrease of the thickness ) but the stresses decrease as well ! This is totally illogical since a decrease of the thickness should necessarily lead to an increase of the stresses.
-When "forces" are used, we obtain a logical behaviour ( lighter final part with lower thickness but higher stresses ).
Could anyone explain why the second model is right in this case ? And also is there a way to still use enforced displacements and get logical results.
Thank you very much,
P.S : the only help I found on Optistruct documentation about the matter is the following paragraph
In order to increase stiffness, minimize compliance should be used with forces and maximize compliance with prescribed displacements.
The compliance is defined as:
Compliance ~ Force · Displacement
When prescribed displacements are used, the reaction force must be increased to increase the stiffness. This means that the compliance has to be maximized.
In case the forces are given, a stiffer structure means having lower displacements. To achieve this goal, the compliance needs to be minimized.
Hello
  • Prakash Pagadala ×
Could you please read this question because it is the complete one. I was not able to delete the other one yesterday.
I used a gauge optimization option where the thickness distribution is even.
Thank you
Edited by rimeca
Hi Rimeca,
I agree with your comment.
Lets us consider case 1:
You are trying to displace a set of nodes on your component to a value through enforced displacement. So in order to achieve this, the component should loose its stiffness to move nodes to that displacement. In your case you need to maximize compliance. So in order to achieve this the component may loose material to be flexible to get enforced to your displacement.
Is the reaction force from Case 1 is same as force applied in Case 2?
Hello Prakash,
In case 2, I took the force that is induced by the enforced displacement ( through SPC Force ) and then imposed that and removed the enforced displacements ( SPC + SPCD )
I understand what you said about "having less material" leads to the part being more able to be displaced and that justifies the results found. But in this case does that mean this is correct mathematically but not really correct physically since this is not what we are really asking Optistruct to do ?
Also, in my optimization problem, my objective function is mass that I want to minimize. Could using the compliance as objective function solve the problem ?
Thank you very much for your help
I need to study the phenomena. I will try on a simple plate to study the behavior. I can give you some feedback soon on this.
So you want to use Compliance as objective and constraint on mass/mass fraction, correct?
Yes, I think you can use this way.
Thank you very much! I will wait for your answer and try the new formulation of the optimization probem you suggested.
I am looking forward to hearing your feedback on the matter.
So I ran a simple topology optimization with force and enforced displacement.
I see both the results same.
I will check with free size and size optimization as well...
Just to update,  I got the same result for enforeced and force model on the same plate.
My Design responses are mass and compliance for Gauge optimization.
