Arul 3 Report post Posted October 15, 2016 Is it possible to calculate the Stiffness (N/m or N/mm) of the structure from any analysis?? Quote Share this post Link to post Share on other sites
Q.Nguyen-Dai 293 Report post Posted October 15, 2016 Yes, it's possible. Apply a force and compute the displacement. So : stiffness = force / displacement Quote Share this post Link to post Share on other sites
Rahul R 316 Report post Posted October 18, 2016 Are you looking for Global Stiffness Matrix Output? If so then use the DMIG approach to generate stiffness matrix for the entire model. Quote Share this post Link to post Share on other sites
Arul 3 Report post Posted October 19, 2016 Hi Rahul , Not Global stiffness matrix. I am looking for stiffness value as output (like Stress, Strain,Displacement). Is there any other way to find out by analysis? Quote Share this post Link to post Share on other sites
Rahul R 316 Report post Posted October 19, 2016 This information should be written in the .out file of Optistruct Run for different types of analysis.Normally we call this as OUTPUT in loadsteps or Global output request under control cards.(Stress, Strain,Displacement) Quote Share this post Link to post Share on other sites
Arul 3 Report post Posted October 20, 2016 Hi, Is it possible to extract stiffness value ( instead of Global stiffness matrix using DMIG) ? Quote Share this post Link to post Share on other sites
Guest Report post Posted October 20, 2016 Hi Arul, If you are looking or stress, dispalcement, strain etc.. in ASCII format, Yes, it is possible. goto Control cards>> Global Output Request>> Stress>> change output format to Opti/OUTPUT. Similarly do the same for Strain, displacement, etc... based on your requirement. If you want to output STIFFNESS (other than global stiffness matrix), no it is not possible. Compliance will be written in .out file, though. Quote Share this post Link to post Share on other sites
Arul 3 Report post Posted October 20, 2016 Hi , Thanks for your reply. How to write Compliance? Quote Share this post Link to post Share on other sites
Guest Report post Posted October 20, 2016 Arul, Compliance will be written in the out file by default for each subcase. Search for compliance in .out file. Quote Share this post Link to post Share on other sites
