Sign in to follow this
Simon D.
Connector 1D Bar to 2D Shell
I tried to connect a 1D Bar (comp id 1) element with a 2D Shell. But when I create a connector Spot weld I always get the error “failed: Link entity 1 (comp id 1) does not have a projection”.
Is it not possible to connect a Bar element with a Shell element using connectors?
Kind Regards,
Simon
Hi @Simon.D
I tried to create a weld using 2D and 1D elements and I faced the same problem.
I will check if there is a way to create welds and update to you soon.
