Sign in to follow this
ppatil
RBE3 Weight factor calculation
I am trying create rbe3 elems using TCL
*createmark nodes 1 101 102 103 104 105 106
*createarray 6 123 123 123 123 123 123
*createdoublearray 6 1.23 1.23 1.23 1.23 1.23 1.23
*rbe3 1 1 6 1 6 100 123456 1.23
In this, How do I calculate weight factor which is in *createdoublearray?
Yes, I have to specify,
but in ACM weld creation method RBE3 is created and upon reviewing element, it will have different weight factor values. How do I get those values here? is there any formula to calculate weight factor?
On 11/7/2016 at 11:03 PM, tinh said:
i think it is specified by you, input it in update subpanel. default to 1.0
so in panel connector>spot, you press F1 and will find out how the values calculated ^_^
