Mithun1991
batchmesher does not extract mid-surface
HI guys,
Need your help regarding batchmesher. I had to mesh an entire bus structure using batchmesher, so initially i divide the bus to a small portion and submitted a run in batch mesher. In the solution , batchmesher had extracted the midsurface and meshed it well. However, when i submit the entire structure, it fails create mid-surface and mesh, whereas it meshes on the outer surface of the structure. In param file i have checked on mid-surface extraction also. but still doesnt work. Please help me out with this regard.
