Jukka
Optimization constrains
The current Inspire 2016 have a heat load case. I would like to know is the heat load case more than the mechanical load from heat expansion? I haven't been able to use the heat input to optimize a heat sink as there are only 'Volume constraint' and 'stiffness constraint' in the optimization.
Is there a possibility of implying a heat constraint?
Do you know if all constraints are mechanical?
Thank you for your answer,
Jukka
