Nithish B S
2D composite analysis
dear all,
I did a 2D composite analysis on a member exactly following the procedure given in this link http://www.altairuniversity.com/analysis/structural/composites/modeling-and-analysis-of-composite-structure/
but the failure index values are zero in the output
kindly check
0_90.fem
0_90.h3d
0_90.hm
0_90.html
0_90.mvw
0_90.out
0_90.res
0_90.stat
0_90_frames.html
0_90_menu.html
hwsolver.mesg
Hi Nitish,
This is because you did not select a failure theory to calculate failure indices.
Card Edit Property>> FT>> Select the failure theory which you would like to use.
