I don't know what am I doing wrong.
I tried to get property name - this works fine.
I tried to get property id - this is not OK.
set entity_name [hm_entityinfo name props $old_prop ] - this will return the property name - everything is OK
set entity_id [hm_entityinfo id props $old_prop -byid ] - this will return the property id as "2" even if the property id is 123123      WHY?:(
Thank you.
On 2016/11/17 at 4:07 AM, ppatil said:
set xentity_id [hm_entityinfo id props $old_prop -byid]
set entity_id [hm_getsolverid props $xentity_id]
should work for you
Hi....
I am trying to get the property ID using the same commands but cannot.
The entityinfo command is not working for ID and the getsolverid is returning both ID and domain.
I tried getentityvalue too but not working.
How can I get only the property ID in a loop. Please suggest.
Thanks in advance!!
