Sign in to follow this
Macro for Bolt Creation
Can any one send me a macro for creating a bolt connections for large assemblies....
Using nastran profile
A beam (CBEAM) element should be created between two spider (Rbe2) elements...
This macro should create a property with PBEAM prop & assign diameter to the Beam element.....
regards,
Selva
Selva,
This functionality of creating bolt connection with CBEAM/CBAR & RBE2 is available within HyperMesh under Connector -> Bolt panel. You may need to write small script to define property automatically.
Rishi
Hi Rishi,
Thanks for ur response......
Thru connectors panel, the holes should be selected manually.
i want a macro such that it selects all the holes with in given a range of diameter & automatically generate bolt connections.
I think u ve a macro for that. if u could please send it across 2 my official mail id.
regards,
Selva
On 12/28/2008 at 2:44 PM, Guest said:
Hi Rishi,
regards,
Selva
PLEASE SEND ME TOO
