Dear Prakash,
Thank you for your response,
First, I would like to inform that I use optistruct solver to do the simulation, with MAT1 material card.
Actually, I only want to know about static stress on it, but the problem is when I set the value of stress legend, the red color show and I don't know the interpretation of that color.
So, I ask this to this forum.
regards,
Iron_Man
Hi @Iron_Man59,
1. What you are seeing is stress-strain curve which is a material property. You can get details of stress-strain curve for material from respective supplier or you can search for the on any material data base.
2. PFA, PDF- NLPARM parameters.
NLPARM (Bulk Data Entry).pdf
@Iron_Man59
It again depends. If you are designing something to failure, use last point.
If you are designing till Yield point, then you need to use yield point value.
