Sign in to follow this
Dirk76
Visualize shell thickness in Hyperview
Hi all,
for a certain purpose I do have to make a cross-section of a plate made up with shell elements. Now I know how to do it but I was thinking, is there a way to visualize the actual shell thickness in Hyperview? It is possible to do it?
Thanks in advance.
It is not possible to visualize the shell thickness in HyperView, as of now. But this feature will be updated in the coming versions.
Thanks guys for the response.
I need it because I wanted to see delamination, since the classical contact gap in HV doesn't work for me and I really don't know why... maybe my solver is too old.
I think I have to do it in LS Prepost.
On 10.10.2017 at 8:57 AM, Q.Nguyen-Dai said:
A small TCL script to export thickness information into HWASCII format from Hypermesh and you can visualize within Hyperview no problem.
Hi Q.Nguyen-Dai.
Could I please get it from you?
is it  possible to visualize the shell thickness in HyperView in Hyperview 2017. As you replied earlier that in the coming versions it would be updated .
If you have HM model with shell elements, thickness is defined via component property, you can test the following code:
*createmarkpanel comps 1 "Select Component"
set mycomps [hm_getmark comps 1]
hm_markclear comps 1;
set myHMDir [file dirname [hm_info hmfilename]]
set outFile "thickness.hwascii"
set fileTypes {
	{"HWASCII" {.hwascii} }
    {"All files" *}
set fileName  [ tk_getSaveFile -filetypes $fileTypes \
	-title "HWASCII data" \
    -initialdir $myHMDir \
    -initialfile $outFile ]
set fh [ open $fileName w ]
puts $fh "ALTAIR ASCII FILE"
puts $fh "\$TITLE = Static Analysis"
puts $fh "\$SUBCASE = 1 Subcase 1"
puts $fh "\$BINDING = ELEMENT"
puts $fh "\$COLUMN_INFO = ENTITY_ID"
puts $fh "\$RESULT_TYPE = Thickness(s)"
puts $fh "\$DELIMITER = ;"
foreach i $mycomps {
	set cname [hm_entityinfo name components $i]
	set elems [hm_elemlist id $cname]
	set prop [ hm_getvalue comps id=$i dataname=propertyid ]
	set thickness [ hm_getentityvalue props $prop \$PSHELL_T 0 ];
	#puts [format "%d %s %d T=%0.3f" $i $cname $prop $thickness]
	foreach eid $elems {
		puts $fh [format "%d;%0.6E" $eid $thickness]
close $fh;
If this macro was executed successfully, you get a file "thickness.hwascii". Export your FE model to Optistruct format for example, you got "mesh.fem".
Within Hyperview, load "mesh.fem" & "thickness.hwascii", you can visualize the shell thickness now.
Here's my screenshot:
Note: My script was tested with NASTRAN profile. Maybe you need some adaptation for another profile.
