Sagar Desai
How to get user input in HYPERVIEW
Ok I will search for that
But will direct tcl commands work in hyperview script?
And it will be really helpful if you give any example script you have
And will it pop up window or where we supposed to enter values?
found how to take input its easy
Quote
puts "Enter your name: "
#flush stdout
set name [gets stdin]
#flush stdout
set name2 [gets stdin]
set sum $name
set sum2 $name2
puts "Hello $sum"
puts "Hello $sum2"
Code for importing geometry in HM is as follows:
*geomimport "auto_detect" "Z:/Users/CAD.stp" "CleanupTol=-0.01" "DoNotMergeEdges=off" "ImportBlanked=off" "ScaleFactor=1.0"
How can I get these inputs like CAD location, tolerance, scalefactor from user when I run TCL script ?
Hi Pritish,
It will be idea for you to create GUI using TK. You can refer to HW GUI Toolkit
1.    From the Start menu, select All Programs.
2.    Select Altair HyperWorks.
3.    Select Tools.
4.    Select HW GUI Toolkit.
You can also refer to the userguide to get started:
https://connect.altair.com/CP/kb-view.html?jf=112968&f=&kb=112938
Pritish Avachat likes this
set filepath [tk_getOpenFile]
set tolerance [hm_getfloat tolerance input]
set scalefactor [hm_getfloat scalefactor input]
*geomimport "auto_detect" "$filepath" "CleanupTol=$tolerance" "DoNotMergeEdges=off" "ImportBlanked=off" "ScaleFactor=$scalefactor"
Hello Guys,
Hope you are all doing well ! Your tutoring has helped me a lot in my initial coding.
Now, I am looking to load a tpl file, but before loading I want to take user input for one variable (say span) and use that variable value in formules mentioned in tpl script.
For that I am thinking to have a window pop up before running tpl file, which will store user input value(span) in one variable ($input)  and then using this $input in further tpl script.
I was able to write this code for poping up window in hypermesh, but this is not working in hyperview when I call same tcl script.
set input [hwtk::inputdialog -text "Enter Span Value" -inputtype str \
    -x [winfo rootx $w] -y [winfo rooty $w]]
tk_messageBox -title "hwtk::inputdialog" -message "Span: $input mm"
1. CAN you guys help me to pop up a window in Hyperview which will store data in a variable ?
2. How to integrate Tpl script in Tcl to achieve my objective ? or any other way to load the tpl file with Step 1 input in it ?
Awaiting your replies !
Tpl does not share variables with tcl
Suppose sample.tpl is your file
Add these tcl codes to dip $input in sample.tpl
set fpt [open sample.tpl]
set buf [read $fpt]
close $fpt
set buf [string map "\$input \"$input\"" $buf]
set fpt [open sample2.tpl w]
puts $fpt $buf
close $fpt
Now open the sample2.tpl
sample.tpl is reserved
HI,
I am trying to get data from hyperbeam Eg. IY,IZ of a solid section. Can you please help me with script or command?
On ‎12‎/‎3‎/‎2016 at 5:03 AM, tinh said:
Hi
i dont know direct command
open window command and enter
tk_dialog
then enter
dump tk_dialog
it is a sample script
HI,
2 hours ago, tinh said:
I mean a surface that fits with the section. Sorry for my english
Hi tinh,
My hypermesh model contains some Hyperbeam sections. Each section will have associated data like shown below,
Area  =    777.34677330
Centroid :
  Local
    Yc  =    0.00369492
    Zc  =    0.00048295
Moments Of Inertia :
  Local
    IY  =    8385.75207149
    IZ  =    292739.17537076
    IYZ  =    0.00138714
  Centroidal
    Iy  =    8385.75189018
    Iz  =    292739.16475806
    Iyz  =    0.00000000
  Principal
    Iv  =    8385.75189018
    Iw  =    292739.16475806
    Angle  =    0.00000000
How can i get this data to text or any readable file by using command because my model has many such beams and I need to extract this details of all the beams.
