Sagar Desai
How to get user input in HYPERVIEW
13 minutes ago, tinh said:
You have to enter hyperbeam GUI first
yes tinh, its working now.. thanks a lot...
I would like to know that is there any command to switche to thyperbeam GUI.
If it works then it would be very easy to get the required data.
I am trying with  *createmark beamsects 1 "solid_section.0" ,
but its not working..hb_getresults will only work if we switch to hyperbeam gui and select the particular beam section and switch back to model gui...
On 10/29/2018 at 12:54 PM, tinh said:
Sure, we have.
::HB_Framework::exit -1
Hello Tinh,
where did you find this command ?
I have searched it in the reference manual but couldn't find it.
Also, is there a way to directly export all the available shell section data as CSV format through the TCL script?
thanks and regards,
Brahmadev.
On 5/17/2019 at 9:42 AM, Livil Lyle said:
Hi Brahmadev,
Refer below link for an idea to directly write data to CSV using Hyperview:
https://forum.altair.com/topic/28913-hyperview-get-list-of-components-and-ids/?tab=comments#comment-75435
Hi Livil,
Actually I was trying to extract data only from the "HyerBeam". and I wanted to extract the data of all shell beam sections into a single CSV file using the script .
Brahmadev.
