Kushgen
Optimise ply orientation for minimum deflection
HI,
The model looks fine, but the orientation after optimization for both the plies is same. Maybe coincidence. Further investigation is required to arrive at a conclusion
I have the geometry underneath consisiting out of a lot of surfaces.
What is the best way to optimise for optimal fibre direction and laminate thickness, so that each surface reveals it's own fibre orientation.
In my previous model I tried assigning all surfaces into a single set:
But after otimization, it seems all the fibre's are directed into the same orientation.
-I need a different orientation and thickness for each surface
Can you help me with this?
Best regards,
Joep
Hi @Joep
I would suggest either do an orientation or thickness. I am more inclined towards thickness optimization instead of orientation.
You can run a three phase optimization to reduce the weight.
I do have this problem now:
After optimization almost every ply has a very small angle of orientation.
Any idea why this is the case?
In the design variables I have assigned a minimum of -180 degrees and maximum of 180 degrees
Could it have something to do with radians? since in other test optimizations it worked with these settings.
Best,
Joep
@Joep
As suggested, it is always better to start with thickness optimization with a varied orientation. Please see the image for more information.
The predicted orientations may not be practical and any degree in the angle may lead to failure.
