Sign in to follow this
hubéry10
Give solid a eigenfrequency
is it possible to give a solid a defined eigenfrequenzy. The Problem is i had to do a modal Analysis of a satellite structure and the first eigenmode had to be above 40Hz, but my tank had a eigenmode at 30Hz. But i know that the frequqnzy of the real tank is 45Hz. So can i give the solid a eigenfrequency with 45Hz?
Thanks for your help
Hi @hubéry10
You can change the frequency by changing mass, material etc...
You can also do optimization (topology optimization, shape optimization) to change the frequency.
