Sign in to follow this
JIGAR PARMAR
Difference between RBEs and CE_STRUCT
In analysis panel under equations you get CE_STRUCT under load types option.
Now I have contacts between several components under my assembly. My job is rested on a fixture.I will be importing my meshed model into Ansys APDL. For defining contacts I am confused between rbes & cestruct.
Jigar,
Are you modelling Ansys deck?
I don't see any CE_STRUCT in OptiStruct under analysis>>Equations>>LoadType. See the attached image.
If your question is based on Ansys solver, I suggest you to contact Ansys support instead.
31 minutes ago, Prakash Pagadala said:
Jigar,
Yes i am working under ansys solver..But the question remains same. Difference between RBEs and CE_STRUCT?  Can I use RBE3 instead of CE_STRUCT ?
