bobo44
Mesh problems bei Feko
I want to mesh and get error
Sphere1.Region58 breaks the symmetry definition. Either it does not have a symmetrical counterpart, or it is not symmetrical around the plane.
How can i remove those planes?
Hi bobo44,
From the image, it would appear that the model isn't symmetrical.  There are three types of symmetry (geometric; electric; and magnetic symmetry).  For each one, you need to understand how the fields and currents will behave in order to know which one is correct.
For this example, I would suggest switching off symmetry planes altogether.  You can do this in CADFEKO on the "Solve / Run" tab -> "Solution settings" group -> Symmetry.  You can learn more about how to utilise symmetry from the User Manual:
  • "3.11.1 Symmetry" explains how to change the symmetry settings in CADFEKO.
  • "26.1 Utilisation of symmetry" gives a more scientific overview of how symmetry can be interpreted and used in FEKO models.
I hope this resolves the problem for you.
Kind regards,
Andries
