dilen
hex mesh for irregular bones
For shrinkwrap there is no need of surface mesh.Just select component & set solid elements with lesser jacobian.I tried with 5 mm element size with .3 jacobian. So its a few click meshing process.
On 1/6/2017 at 11:47 PM, tinh said:
I think your splits are not mappable
my strategy is like this (sorry it's not completed :rolleyes:)
cal_half.hm
Hello Tinh,
I am running into an issue hex meshing a muscle STL. I was wondering how you drew the outlines that separated the solid object into multiple sub-components which could then be meshed. In the example you provided, only one of these components is hex meshed and this looks like the process I need to follow to fix my problem. I am new to HyperMesh, so any advise you could provide would be of great help.
Thank you,
Jack
