Hi all,
Hopefully a really simple one to solve.
I have a simple model, working as a demonstrator.
2 Components, one locked in place whilst the other is driven into it. I have a contact between the two.
I need the simulation to terminate when the contact force reaches 100kN. I believe the strategy is /STOP/LSENSOR. Sensor = /Sensor/INTER... TYPE 6.
However, I cannot get the simulation to kill at 100kN.
Here is the sensor (Fmin = -1, Fmax = 100).
## Sensors
/SENSOR/INTER/1
SENSOR
         1                          -1.0               100.0                 0.0
The issue seems to be when the simulation starts, the sensor activates. I've run the model without the sensor and it ranges from 0 to 200kN. I have tried varying the numbers but that does not alter the outcome, every attempt begins with sensor being activated.
HELP!!!!
Many thanks in advance.
Andy
Hi Andy,
As a workaround, select the direction as Normal Force and provide only Fmax.
If you still face issues, please share the model (starter and engine files) files.
Many thanks George,
I managed to get it working. Here's what worked in the end....
/SENSOR/INTER/1
SENSOR
#         Tdelay
#   Interf       DIR                Fmin                Fmax                Tmin
         1        NF               -50000              3200                    0.000
On 1/24/2017 at 8:45 PM, Andy@LamteqSolutions said:
Many thanks George,
/SENSOR/INTER/1
SENSOR
#         Tdelay
how did you work out in this method as you need to stop at 100 kn but in this setup you used -50000 and 3200 .we also have the same issue but couldn't able to find out the solution ,please guide us .thanks in advance .
