Corentin
Visualization problem on HyperView
I have a problem when I want to watch my results on Hyperview. Indeed, the numeric value (of the displacement for example) displayed/computed is correct, but during the animation, we can see the displacement does not reach the value (really small displacement animation compare to the value)... I guess it is a problem about the display only.
I checked the Scale factor and changed it ('deformed' button), but when I chose beyond around 20, the display diverge/'explode'. Besides, it is not high enough to clearly see the 'real' displacement (value displayed).
Can you help me please?
Thank you,
Corentin
Hi Corentin,
This seems like an animation control issue. Please check the animation mode.
I suggest you to go through the HV-1010: Using the Animation Controls tutorial where all the parameters are explained.
