Sign in to follow this
RishabhAwasthi
Error for puts Stdout
I facing problem while using command puts stdout. I am trying to display some text along with value of variable . I am getting the following error :
can not find channel named "stdout".
I noticed this similar kind  of error while executing : puts Hello World. Error is: can not find channel name "Hello". This error occurs because puts needs two arguments :1st one I/O stream identifier (output,error,input) and string so this command doesn't identify Hello as valid stream identifier. But since I am using stdout, this error shouldn't come.Also it working fine is some system,while in others it is showing error.
