I´m trying to simulate a weld with the seam panel to connect a t-joint. The t-joint consists of two plates which are meshed with solids. The two plates are selected for the “components”. For the seam weld I´m using the „penta (MIG + T)“-type. When I want to realize the seam weld I always get the message “Failed: Link entity 1 (comp id 1) and link entity 2 (comp id 2) do not have projections”. Is someone able to tell me what´s the problem and how can I fix this?
Many thanks in advance for your help!
Regards
Nina
