jcd
Unfreeze the HyperMesh GUI
Is there a simple way by which I could unfreeze the HyperMesh GUI (either a tcl command or through an option in the GUI itself) ? I've been running a long tcl script after the completion of which , the model in the GUI completely freezes. The rest of the HyperMesh GUI works fine but I cannot rotate / shift / select the model / geometry in any way.
Any help is appreciated.
Please show us your script. Normally hm will not be frozen after the script finished
while a script is running, you can use command "update" - hm will respond with events
@tinh : Yes, update did result in the hm gui responding to mouse events. Thank you. There was also an issue with my GUI script itself which was resulting in this error.
Thanks.
