I came across in the documentation that the life is calculated using the formula.
Sr = SRI1(Nf)b
But, even after maintaining the co-efficients, TRTMENT, FINISH and [KF] as 1, the results are off (when compared with the manual calculation using the above mentioned formula) by a random factor (approximately 0.5), for each unique component I take for fatigue analysis (Refer image attached). Why is it so?
What is the calculation happening at the back end of the software?
Why is the factor 0.5 coming into play?
Hi @SKGPrashanth
Is it possible to share the model file with us so that we can have a deeper look into the model?
Please share file using File Transfer link available in my signature.
Hi Pranshanth,
Thank you, Can you let me know what is the maximum and minimum loads or Stress amplitude and mean stress?
Prashanth,
Thank you.
Since you mentioned as maximum stress, I wanted to confirm with you about the Sa and Sm.
I will check and update to you soon.
On 3/16/2017 at 3:50 PM, Prakash Pagadala said:
Prashanth,
Thank you.
In the meanwhile, I tried the exact same problem in Ansys Workbench; where I got exactly the same result as that from the formula.
What am I missing out in Radioss?
This reply is on behalf of Prakash & Expert.
SN curve in OS is based on the stress range. Stress range = 2*amplitude.
Looks like Ansys is using amplitude instead of stress range.In future version we will have option to choose between amplitude and range.
Thank You, @Rahul R and @Prakash Pagadala for your efforts.
Based on your answer, I doubled the stress amplitude value and then substituted the resulting stress range in the formula Sr = SRI1(Nf).
When I used this new SRI1 value(It is double the old value), I'm getting the results as expected.
One last question. Does the formula Srange = 2×Samplitude hold good even for load curves that are not sinusoidal?
HI,
No, since Sr= 2*Sa we used this in the equation but for Sfl or FL it is not required to double the value.
