Sign in to follow this
Rahul Ponginan
Click2Extrude
solidThinking® Click2Extrude™ Metal and Polymer are simulation based environments designed to help metal and polymer extrusion companies meet the ever increasing demands to produce complex profiles with tight tolerances, quality surface finishes and high strength properties at reduced cost. Click2Extrude Metal and Click2Extrude Polymer are virtual presses where users can visualize material flow and temperature inside a die during extrusion and make necessary changes to ensure balanced flow, while identifying and eliminating product defects.
Click here to learn more
This topic is now closed to further replies.
