Sign in to follow this
yao
Disabling SELinux
This issue is caused by SELinux. At the current time, the only way to work around this issue is to turn off SELinux. This typically needs to be deactivated by the root user. Using the GNOME desktop environment, this can be done by running system-config-securitylevel and selecting the "SELinux" tab. Disable SELinux and apply the settings.
