Yousif
1D BEAM ANALYSIS
I am currently carrying out a 1D beam analysis. My results and the contour on my beam seems patchy and unclear.
I have attached the file of the beam and results for you to understand.
It is a distributed load of 150N between 32mm-109mm and 222mm-299mm.
Could you please tell me how to make the contour line more visible. I have tried to change the range, but it did not make a difference.
Thank you,
Yousif
1D beam.mvw
1D beam.hm
Hi Yousif,
I see element id 1 was the reason for patchy and unclear results(it was through from one end to another end).Just delete & rerun.PFA displacement plot for FYR.
tinh likes this
Oh, I thought it is due to graphic problem. because when I open h3d file directly, it is not patchy
when I open hyperview via menu button "View" on optistruct solver window, it is always patchy.
