Sign in to follow this
yao
Why can't I get AcuConsole to display properly on my Linux machine?
AcuConsole uses Coin3D for visualization. Coin3D ( http://www.coin3d.org )requires OpenGL. There are multiple sources of problems with display. 1. OpenGL is not installed on your machine. Try running "glxgears" application as a test. 2. The graphics driver used. On Linux try running /sbin/lspci to see the drivers for your video controller. 3. On Linux, check the following files ( mail it to our support ), /etc/X11/XF86Config and /usr/X11R6/lib/X11/Cards
