I am trying to 3D mesh this model with solid mapping.
I have already tried 'toggle edges' and 'trim with surf'. I have also tried to divide the circular plate (top plate) into small pieces by connecting the nodes, however, I was not able to split any surfaces.
I am not exactly sure which edges I should toggle and how I should get rid of the narrow surfaces between the rectangular (side) surfaces, to make the model mappable?
Thank you,
Muge Candogan
Hello Rahul,
Thank you very much for your quick response.
I am trying to create hex elements with solid mapping. Since the geometry is complex, would there be an easier way to mesh that you recommend?
I am also sharing the hm. file to your dropbox.
Thank you very much,
Muge Candogan
thanks for sharing files.Hex mesh with solidmap is all about how you are splitting model to get mappable volume.to me also it seems complex.PFA screenshot for same.Will check & let you know my finding on this model.
