bhumkaromkar
Fatigue analysis Minimum life is coming less than 1
Hello all,
I have done static analysis of the structure using static load case of 971N. I have applied Fully reversible sinusoidal curve (100 cycles) for fatigue analysis in optistruct. SN curve is calculated in optistruct using UTS. After analysis i am getting minimum number of cycle as 1.581e-2 which seems unrealistic.
What can be the problem?
Rahul R likes this
Fatigue life is mainly dependent on b and fatigue strength coefficient. Check the parameters and Stress amplitude is directly available from maximum and minimum loads and try again.
@ Prakash Pagadala
I am using SN life method for stress calculation.
For this SR1, B1 and NC1 values are directly estimated using UTS in fatigue process manager.
I have used this approach. Are their any additional values needed ?
TIA.
I used following values
YS= 340 MPA
UTS =  497 MPA
Values calculated in Fatigue process manager for SN curve Plot (Estimated based on UTS option)
SR1 = 2118.71
B1= -0.125
NC1 = 1e6
B2, FL, SE are OFF.
