Hi Prajval,
There are 2 methods by which you can calculate the area under the curve, Abs Area and Signed area.
If you plot any curve and go to Statistics panel and select a curve it populates with all the relevant information.
For your reference I have attached 2 documents.
absarea.pdf
signedarea.pdf
The area under a curve between two points can be found by doing a definite integral between the two points. To find the area under the curve y = f(x) between x = a and x = b, integrate y = f(x) between the limits of a and b. Areas under the x-axis will come out negative and areas above the x-axis will be positive.  www.integral-calculator.co
