Sign in to follow this
yao
Why can't I read the .op2 file into AcuConsole that I wrote from NX Nastran / FEMAP?
By default, the nodes and element connectivity are absent from the OP2 file. This is done by design. FEMAP writes a parameter "PARAM OGEOM NO". This means do not write geometry to the op2 file. This is done because the pre-processor already has the geometry loaded and hence it needs only the results from the file.
Workaround:
Simply disable this parameter using the deck editor in FEMAP or remove this parameter by editing the deck outside of FEMAP
