Simonec
Optistruct not finishing analysis
I'm having an issue with Optistruct: when running an Analysis Optistruct seems to finish it giving "Job complete" but opening the .out file you can clearly see that analysis isn't complete.
I'll attach both the .out and .stat files
Thank you
Piastra_libera_ASET.stat
Piastra_libera_ASET.out
P.S: the issue seems to disappear without the ASET load collector, could that be the cause?
Can you check if there is any H3D file written in your working directory?
If possible, please share the model file.
Hi @Simonec
I ran the model you shared on HW 14.0 Student Edition as it is and it worked. The problem could with the software or with the machine.
Can you update HyperWorks at your end and can you try again?
HyperWorks 2017 Student Edition is available for download. You can order your free license to start using HyperWorks 2017 Student Edition.
http://www.altairuniversity.com/free-hyperworks-2017-student-edition/
