JM Desrosiers
1D element spring as real springs
I'm new to hypermesh and I have a simple question for you guys. Can we use a spring element to act like a real coil spring? In fact, I got an impactor hitting a dummy and in the real experiment, the impactor is stopped at a certain distance from it's initial position by a coil spring. I wanted to use a imposed displacement, but I need to keep the initial velocity to allow the impactor to slow down by transferring its energy to the dummy. So, I thought that maybe I can stop the impactor (which is rigidbody) by a spring element like it is in real experiment. Can I do that? Or is there something else I could do? So far, I wasn't able to use the spring correctly.
Thank you very much!
Hi JM,
You can actually define a time history curve which defines the imposed displacement and attach it to the master node of the RBODY ( Impactor)
The time history curve can be defined in a such a way that, it is impacted with certain displacement to begin with and the displacement dies down to zero.
For example:
X (time)    Y(Imposed Displacement)
0.0             0.0
0.1             1.0
0.2             3.0
0.3             0.0
Above, the hammer moves a distance of 3mm at 0.2sec  and comes to it's original position at time 0.3sec.
If you want to connect the Hammer with a spring and control the motion, then you can actually define a load vs displacement curve similar to the above with /PROP/SPRING property card
Let us know if this helps!
Thanks,
Vikas
Hi Vikas,
I thought using this option, but I really need to lauch my hammer at a certain velocity (initial velocity). Therefore, I don't want to impose a displacement to the hammer. I only want to stop it by using a coil spring. But, maybe I can define a component which would be a coil spring and add a interface between the 1D coil spring and my 3D impactor? The coil spring would be at a certain distance from the initial position of the hammer. So the hammer will impact my dummy and be stopped after the impact at a certain distance.
I don't know if I'm clear or not, but thanks for your response!
JM
Hi JM,
Yes, in case you don't want to impose a velocity to control the hammer as i suggested above you can attach few springs to the nodes of the hammer and define the load vs displacement curve to the spring element using /PROP/SPRING card.
Let us know how it goes!
Thanks
Vikas
Rahul R likes this
