Ramakiran
USING RIGID PROPERTY AND AMS AT SAME TIME
SIR,
I have encountered an error saying id, RIGID MATERIAL LAW cant be used along with AMS- Advanced mass scaling, Try modeling as \rigidbody, but i havent found any rigid body except 1d rigidss, can you guide me through this as i am doing imposed displacement problem.
Thank you for your proactive approach of answering..
Please provide the .out file containing the error.
Also you can go making the complete component as RBODY and make IcoG 2: This also makes the same thing as Rigid material law. Also there are certain limitations with rigid material law of which is with AMS.. I have attached the image for reference.
Hi Ramakiran,
Instead of /MAT/RIGID use /MAT/ELAST (Mat Law 1)  and try running the analysis.
I tried that but plate is rebounding back if do like that..I need model in. \rbody..I want to know where this card is available in hypermesh and where the flags icog etc are available
