Ahanvoth
Analysis of Thickness vs. Displacement
I'm currently attempting to do a study in which I created a simple square mesh. A pressure is applied perpendicular to the entire surface and the geometry is constrained along two parallel edges of the square. I'd like to observe the change in element displacement as the thickness varies. Is there any way to do this by parameterizing the thickness within the PSHELL component? I have attached an image of the setup to clarify.
@Ahanvoth
The attached model is simple plate (5mm) with pressure applied. I have included gauge optimization in the model which varies thickness from 5mm to 0.1mm.
The attached h3d files have thickness variations and displacement results. You can study the results for corresponding change in thickness.
